I self-hosted my own Miniflux instance and just wanna try NewsBlur. I know I can signup in public instance but is there any benefits of self-hosting one? Can I enjoy premium functions in self-hosted NewsBlur?
You would get the premium features by self-hosting, but that comes at the cost of hosting it. If you already have a way to host it, it might be worth it. Bare minimum hosting for something like Linode or Digital Ocean is already $5/mo. At the end of the day, I use NewsBlur for a couple hours a day so $3/mo seems reasonable for Samuel to have to deal with all that infrastructure nonsense, and I say that as someone that deals with all that infrastructure nonsense for my day job.
Perhaps youāll find joy with https://fly.io/
Yep, self-hosting gives you all the benefits of unlimited premium accounts. You can also tune the unread date to be as long as you like, so a feedās stories can stay unread for as long as you like.
Iāll warn you though, youāll be paying a lot more than $3/month in electricity if you choose to self-host.
Hereās the instructions:
Basically, download the repo and type make nb.
I already own my self-hosted machine so I really dun mind adding 1 more container =) I need to taste whether NB suits my ready habit.
BTW, is it only support x86 docker? I failed to make nb in my arm machineā¦
Should be able to run now, we just shipped multiarch docker builds.
I finally mastered to get all the containers up. But I am finding a way to access in outside LAN.
When it is put behind the nginx proxy in my home network, it returns me too many redirectsā¦
I got every containers up but when I access it shows 502 Newsblur is down. Any idea?
Check the docker logs for newsblur_web container.
I only got 1 line āConnected to postgresā for newsblur_web. But for docker logs haproxy it has:
backend ānode_xxxā has no server available!
backend āelasticsearchā has no server available!
backend āgunicornā has no server available!
And here is the node logs:
[2022-02-13 08:12:48] ---> ---> No .env file found, using defaults [2022-02-13 08:13:11] ---> Starting Original Page server on DEV [2022-02-13 08:13:11] ---> Starting NewsBlur Original Text Fetcher / Mercury Parser... [2022-02-13 08:13:11] ---> Running as development server [2022-02-13 08:13:11] ---> Starting NewsBlur Favicon server... [2022-02-13 08:13:11] ---> Running as docker server [2022-02-13 08:13:11] ---> Starting NewsBlur unread count server... [2022-02-13 08:13:11] ---> Running as docker server [2022-02-13 08:13:13] ---> Starting NewsBlur Node Server: localhost [2022-02-13 08:13:13] ---> Connected to db_mongo:29019
Looks normal tooā¦
Whatās the output of ādocker psā?
docker ps -n 10
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
94b8e7d47632 haproxy:latest "docker-entrypoint.sā¦" 5 minutes ago Up 5 minutes 0.0.0.0:80->80/tcp, :::80->80/tcp, 0.0.0.0:443->443/tcp, :::443->443/tcp, 0.0.0.0:1936->1936/tcp, :::1936->1936/tcp haproxy
398f31863c97 nginx:1.19.6 "/docker-entrypoint.ā¦" 5 minutes ago Up 5 minutes 80/tcp, 0.0.0.0:81->81/tcp, :::81->81/tcp nginx
fcece3e613bb newsblur/newsblur_python3:latest "/bin/sh -c newsblurā¦" 6 minutes ago Up 5 minutes 0.0.0.0:8000->8000/tcp, :::8000->8000/tcp newsblur_web
d83220c98b3b newsblur/newsblur_node:latest "docker-entrypoint.sā¦" 6 minutes ago Up 5 minutes 0.0.0.0:8008->8008/tcp, :::8008->8008/tcp node
4422ef5f38b3 postgres:13.1 "docker-entrypoint.sā¦" 6 minutes ago Up 6 minutes 0.0.0.0:5434->5432/tcp, :::5434->5432/tcp db_postgres
fcbc9133f0b8 redis:latest "docker-entrypoint.sā¦" 6 minutes ago Up 6 minutes 6379/tcp, 0.0.0.0:6579->6579/tcp, :::6579->6579/tcp db_redis
b18e4a549a9c ghcr.io/willnorris/imageproxy:latest "/app/imageproxy -adā¦" 6 minutes ago Restarting (1) 44 seconds ago imageproxy
3bf47ff0a2b7 newsblur/newsblur_python3 "celery worker -A neā¦" 6 minutes ago Up 6 minutes task_celery
dbf42eed04dd docker.elastic.co/elasticsearch/elasticsearch:7.16.2 "/bin/tini -- /usr/lā¦" 6 minutes ago Up 6 minutes 0.0.0.0:9200->9200/tcp, :::9200->9200/tcp, 0.0.0.0:9300->9300/tcp, :::9300->9300/tcp db_elasticsearch
3f84cf896850 mongo:3.6 "docker-entrypoint.sā¦" 6 minutes ago Up 6 minutes 27017/tcp, 0.0.0.0:29019->29019/tcp, :::29019->29019/tcp db_mongo
Just notice imageproxy is restartingā¦and docker logs show
standard_init_linux.go:228: exec user process caused: exec format error
What version of docker compose are you using? It seems the containers canāt talk to each other.
I just upgraded from 1.21 to 1.28.4, they seems can talk to each other now, localhost can redirect to the web but the page looks frozen.
imageproxy still keep restarting:
I am guessing if imageproxy does not support armā¦
I requested arm support in imageproxy here:
Glad upgrading fixed the issue! I havenāt seen a frozen page but Iād love to know if thatās because of anything not loading. Does the web inspector console show anything?
This morning I attempted to use the arm port of imageproxy (basecamp/imageproxy). The imageproxy is working but the page is still as shown. I canāt click to Sign In.
But I can click on the bar below now (e.g. ios). And I can scroll this page.
and here are the haproxy logs now:
[NOTICE] (1) : path to executable is /usr/local/sbin/haproxy
[WARNING] (1) : config : parsing [/usr/local/etc/haproxy/haproxy.cfg:49] : a 'monitor fail' rule placed after a 'redirect' rule will still be processed before.
[WARNING] (1) : config : parsing [/usr/local/etc/haproxy/haproxy.cfg:50] : a 'monitor fail' rule placed after a 'redirect' rule will still be processed before.
[WARNING] (1) : config : backend 'node_socket' uses http-check rules without 'option httpchk', so the rules are ignored.
[WARNING] (1) : config : backend 'node_favicon' uses http-check rules without 'option httpchk', so the rules are ignored.
[WARNING] (1) : config : backend 'nginx' uses http-check rules without 'option httpchk', so the rules are ignored.
[NOTICE] (1) : New worker (8) forked
[NOTICE] (1) : Loading success.
[WARNING] (8) : Health check for server node_socket/node_socket failed, reason: Layer4 connection problem, info: "Connection refused", check duration: 3ms, status: 0/2 DOWN.
[WARNING] (8) : Server node_socket/node_socket is DOWN. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
[ALERT] (8) : backend 'node_socket' has no server available!
[WARNING] (8) : Health check for server node_favicon/node_favicon failed, reason: Layer4 connection problem, info: "Connection refused", check duration: 1ms, status: 0/2 DOWN.
[WARNING] (8) : Server node_favicon/node_favicon is DOWN. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
[ALERT] (8) : backend 'node_favicon' has no server available!
[WARNING] (8) : Health check for server node_text/node_text failed, reason: Layer4 connection problem, info: "Connection refused", check duration: 2ms, status: 0/2 DOWN.
[WARNING] (8) : Server node_text/node_text is DOWN. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
[ALERT] (8) : backend 'node_text' has no server available!
[WARNING] (8) : Health check for server node_page/node_page failed, reason: Layer4 connection problem, info: "Connection refused", check duration: 0ms, status: 0/2 DOWN.
[WARNING] (8) : Server node_page/node_page is DOWN. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
[ALERT] (8) : backend 'node_page' has no server available!
[WARNING] (8) : Health check for server postgres/db_postgres succeeded, reason: Layer4 check passed, check duration: 1ms, status: 3/3 UP.
[WARNING] (8) : Health check for server mongo/db_mongo succeeded, reason: Layer4 check passed, check duration: 0ms, status: 3/3 UP.
[WARNING] (8) : Health check for server gunicorn/app_django failed, reason: Layer4 connection problem, info: "Connection refused", check duration: 1ms, status: 0/2 DOWN.
[WARNING] (8) : Health check for server redis/db_redis succeeded, reason: Layer4 check passed, check duration: 1ms, status: 3/3 UP.
[WARNING] (8) : Server gunicorn/app_django is DOWN. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
[ALERT] (8) : backend 'gunicorn' has no server available!
[WARNING] (8) : Health check for server redis/db_redis_pubsub succeeded, reason: Layer4 check passed, check duration: 1ms, status: 3/3 UP.
[WARNING] (8) : Health check for server redis_story/db_redis_story succeeded, reason: Layer4 check passed, check duration: 0ms, status: 3/3 UP.
[WARNING] (8) : Health check for server redis_sessions/db_redis_sessions succeeded, reason: Layer4 check passed, check duration: 0ms, status: 3/3 UP.
[WARNING] (8) : Health check for server elasticsearch/db_elasticsearch failed, reason: Layer4 connection problem, info: "Connection refused", check duration: 0ms, status: 0/2 DOWN.
[WARNING] (8) : Server elasticsearch/db_elasticsearch is DOWN. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
[ALERT] (8) : backend 'elasticsearch' has no server available!
[WARNING] (8) : Health check for server node_images/node_images succeeded, reason: Layer7 check passed, code: 200, check duration: 3318ms, status: 3/3 UP.
[WARNING] (8) : Health check for server node_socket/node_socket succeeded, reason: Layer4 check passed, check duration: 0ms, status: 1/2 DOWN.
[WARNING] (8) : Health check for server nginx/nginx succeeded, reason: Layer4 check passed, check duration: 1ms, status: 3/3 UP.
[WARNING] (8) : Health check for server node_favicon/node_favicon succeeded, reason: Layer4 check passed, check duration: 0ms, status: 1/2 DOWN.
[WARNING] (8) : Health check for server node_text/node_text succeeded, reason: Layer7 check passed, code: 200, check duration: 368ms, status: 1/2 DOWN.
[WARNING] (8) : Health check for server node_page/node_page succeeded, reason: Layer7 check passed, code: 200, check duration: 163ms, status: 1/2 DOWN.
[WARNING] (8) : Health check for server node_socket/node_socket succeeded, reason: Layer4 check passed, check duration: 0ms, status: 3/3 UP.
[WARNING] (8) : Server node_socket/node_socket is UP. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
[WARNING] (8) : Health check for server node_favicon/node_favicon succeeded, reason: Layer4 check passed, check duration: 0ms, status: 3/3 UP.
[WARNING] (8) : Server node_favicon/node_favicon is UP. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
[WARNING] (8) : Health check for server node_text/node_text succeeded, reason: Layer7 check passed, code: 200, check duration: 5ms, status: 3/3 UP.
[WARNING] (8) : Server node_text/node_text is UP. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
[WARNING] (8) : Health check for server node_page/node_page succeeded, reason: Layer7 check passed, code: 200, check duration: 6ms, status: 3/3 UP.
[WARNING] (8) : Server node_page/node_page is UP. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
[WARNING] (8) : Health check for server gunicorn/app_django succeeded, reason: Layer4 check passed, check duration: 0ms, status: 1/2 DOWN.
[WARNING] (8) : Health check for server gunicorn/app_django succeeded, reason: Layer4 check passed, check duration: 1ms, status: 3/3 UP.
[WARNING] (8) : Server gunicorn/app_django is UP. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
[WARNING] (8) : Health check for server elasticsearch/db_elasticsearch succeeded, reason: Layer4 check passed, check duration: 1ms, status: 1/2 DOWN.
[WARNING] (8) : Health check for server elasticsearch/db_elasticsearch succeeded, reason: Layer4 check passed, check duration: 0ms, status: 3/3 UP.
[WARNING] (8) : Server elasticsearch/db_elasticsearch is UP. 1 active and 0 backup servers online. 0 sessions requeued, 0 total in queue.
That first screenshot is showing a broken NewsBlur missing a CSS file. What do you see in the web inspector when you look for broken links or CSS. Is it a 404 to a CSS file? What is that URL? Do you have DEBUG_ASSETS turned on or off in docker_local_settings.py or your own local_settings?
