Starting sometime after 22:15 pst on the 25th a significant number of my feeds broke and won’t repair/reload through the “fix a misbehaving site” steps. I’ve tried it for all listed below. I’ve also tried reading the sites, logging out and back into my account. This behavior is across all devices, the web version and iOS app. Any suggestions would be appreciated. Thanks
Looks fine on my local machine, and it’s showing 403’s on the web, which means they are blocking NewsBlur. You should email them this template:
Hi, I use NewsBlur.com, an RSS reader, and your RSS feed stopped working on February 24th. NewsBlur just changed hosting providers and now has a different set of IPs. NewsBlur’s IPs are being blocked (HTTP 403). I’d like to request that they are unblocked. Here is a handy list of IP addresses that NewsBlur uses: https://www.newsblur.com/api/ip_addresses/
Thanks for the template. I’ve sent notices to all of the offending sites and hoping to remain a premium subscriber. However, If they don’t make the requested changes (which they haven’t to date) does that mean that NewsBlur will no longer support these sites?
I’m working on it. It’s a Cloudflare issue. Try contacting Cloudflare and let them know. If enough people complain to Cloudflare they might whitelist newsblur. They’ve done it before but my contacts there are ghosting me.
Same here with https://www.rte.ie/feeds/rss/?index=/news/
I need to go into the All view button bottom left, then select the feed itself, and then select Insta-fetch Stories.
Then I can go back to the Unread view to read them with the rest of my feeds.
I’m also having this issue with https://www.aopa.org/rss.
The solution posted by rpokane here does not resolve the issue.
@samuelclay, sorry to tag you, but is your recommendation still to complain to Cloudflare using the template you provided here?
For free users (which I would be since I cannot get anywhere on their support website without making an account), it looks like the only options available are to post on their community forums or in their discord channel.
