I use Newsblur to keep up with some scientific journals’ “Current issue” feeds, which sometimes dump 60-100 items in with the same timestamp. I have noticed that Newsblur consistently only recognizes 50 items. Two feeds where I have seen this behavior are http://feeds.feedburner.com/pnas/SMZM (today) and http://feeds.feedburner.com/jbc/SUcv (for the past few weeks) - it may also be relevant that they are both feedburner feeds. The missing articles never show up, as far as I can tell.
Yeah, if NewsBlur doesn’t see the story in time, it won’t show up. No way around that unless more people subscribe to the feed and it fetches more often. You can see by right-clicking on the feed and opening Statistics.
So, the Proceedings feed is followed by 155 people and checked every 10-15 minutes according to the statistics. JBC is only followed by 9 but for some reason is set to real-time. I also saw this issue again today with the Nature Current Issue feed (http://feeds.nature.com/nature/rss/cu…) which is followed by 734 people, and has stories arriving in real time supported by a supplementary check every 2-2.5 hours. So, it seems to me that based on the stated fetch frequency I should be seeing all the items from these events in a timely manner.
Even were this not the case, I find your answer pretty confusing. I mean, regardless of how often it’s being checked, it isn’t like the tail ends of those blasts are just disappearing from the feed. They’re still there; when I manually check the feed I can see them. If they’re not recognized in the first check they should be picked up in the second, whenever that happens. So, if Proceedings publishes 75 articles to its feed within a few minutes on a Tuesday and only 50 show up on the first check, then the other 25 should show up 10 minutes later at the next check, right? But they never do. Those 25 items go into limbo and never appear, period.
I think this “feature” is making NewsBlur pretty much useless for following scientific journal feeds.
As far as I can tell, these feeds work by pushing the entire contents of one journal issue in one go. In case of the above mentioned Nature Current Issue feed, the latest issue seems to contain 73 stories. Very annoyingly NewsBlur only ever fetches the first 50, and the last 23 are lost forever.
Increasing the update frequency will not help because the publication of the 73 stories appears to be atomic. Instead the arbitrary limit of 50 stories per update should be raised much higher.
This seems to be one of the main issues with the dx.com feed also. (It has usually 3-500 items in each update, but only 50 is show’n, but most oftenly Newsblur times out when it’s fetched)
Ok, yet another odd NewsBlur restriction… this service is starting to look really bad. Sorry for saying but at first NewsBlur looked really great but constantly I’m finding out these restrictions (which do not go away even if I’d pay) which are NOT DOCUMENTED… I’m starting to be really disappointed and it seems that I’ll have to find another service… damn you google for quitting reader… it seems that there’s really no good alternative around.
Here’s one of my feeds that are affected by this max 50 items stupidity: http://www.levykauppax.fi/feed/coming/
Google Reader worked just fine with this feed.
For the past few days I’ve been testing NewsBlur, Feedly & g2reader side by side and testing DealExtreme feed (among other things too) and this max 50 items problem with NewsBlur.
NewsBlur: DX feed returns only 50 items. (today about 300 new items in the actual RSS feed)
g2reader: seems to fetch all ~300 items but all are marked as “read” automatically because the site puts the feed in to “passive mode” because it contains hundreds of new items every day.
Feedly: all ~300 items are fetched AND all are marked as unread!!!
So long NewsBlur, for now… Feedly is a great service (it doesn’t have many other restrictions that NewsBlur has). It’s not perfect, it has some minor things to fix/develop, but it really seems to be the only choice to replace Google Reader (and I’ve tested over 10 alternatives).
Good luck NewsBlur, keep developing your service, currently it’s “number 2” in my list, and I might check back someday. Thanks for the hard work.
Samuel, Can you please respond to this or one of the other two tickets that report the issue with DX.com only recieving 50 items each time the feed is updated with 300+ items?
As a paying member I must say that the lack of response on this is really bad.
Markus, this is the third thread you’ve posted in for the same issue. Please stop posting the same issue, especially as I answered your question already. Not only that, but I answered this thread above, as well.
As a paying member, you’re entitled to a refund if NewsBlur isn’t fulfilling your needs. Email me and I’d be happy to give you one.
No, you haven’t touched on the issue above.
The timeout’s you commented on 6 month’s ago is not the same thing as the limitation that makes the DX and other feeds stop at 50 items.
The reason I did this mass-post was that you didn’t respond to anyone before. It seems to have worked.
I would prefer if I could use NewsBlur, but if this isn’t something that you plan to fix, please let me know.
OK, I bumped the limit from 50 to 100 at a time. I hope it doesn’t have any negative effect on my feed fetchers performance, because if it does, that limit, which was put in there for good reason, is going right back in. But I have a feeling I’ll be able to absorb it just fine.
Here’s the commit: https://github.com/samuelclay/NewsBlu…
Does that mean that we will get all 300 new items, but at 100 items at a time (and that NewsBlur will loop through the feed more than one time) or does that mean that feeds that update more than 100 items at a time will keep loosing them?
You claim that the limit is 500 items per feed in this ticket:
https://getsatisfaction.com/newsblur/…
But is that only possible if the site that creates the feed trickles the items at max 100 items at a time?
The max is 100 stories at a time.
So, any feed that has more than 100 updates at a time will just be truncated and the additional items will be lost forever without any notice to the user?!?
