The feed for http://whatever.scalzi.com/ is not updating
Right-click on the feed and open Statistics. That should show you what’s happening.
I did that before reporting the problem. The blog is not updating and has not updated in well over a week.
It looks ok from here, updates regularly and didn’t miss any stories.
Maybe you should try checking your RSS link or re-adding it. Re-adding mostly solved my problems like yours.
I tried that several times. Will try again.
It’s been working fine for me. What is the feed URL you are using? For reference, I have http://whatever.scalzi.com/feed/atom/
