The unread count on some feeds is not updating ( http://goo.gl/kGpEI ); as you can see, there are two unread articles in this feed but there is not unread count for it, while other feeds are working correctly. Thanks.
Iāve also noticed that, especially on some feeds, some stories are being marked as āreadā, even thought they are actually āunreadā.
Iām also having the same problem. I try to do most of my reading of folders with the view set to āunread onlyā and I now find Iām missing a number of unread articles because the feed is showing 0 unread. Iām now having to open each individual feed to make sure Iāve found all unread items. When you look at the individual feeds the articles show as unread yet the total unread count is 0.
Hmm, I mustāve done something to how those feeds are counted. I bet this is a direct result of the real-time push though. So I need to figure out some way to update those unread counts. Maybe Iāll move the refresh_feeds call back to its normal speed.
This issue is still happening for me.
Itās happening for me, too. I started a topic about this around 5 months ago and must not have seen this earlier one at the time. (The other topic is https://getsatisfaction.com/newsblur/topics/sidebar_shows_no_unread_items_in_a_feed_but_main_pane_correctly_show_unread.) Also as yet resolved. Iām pretty sure itās the same issue, so Iāll start watching this topic as well.
I still experience this problem as well.
FWIW, in my case with a feed Iām particularly interested in it happens that while when I explicitly open it, I correctly see unread stories but the unread counter in the sidebar is always 0.
In my case it can be that the feed in question has two stories with incorrect dates (both in 2014). Which is an error for sure but the unread count is always 0.
iām also seeing this on a very regular basis (every day).
on the desktop site, iāll read everything in a feed but it will show as having 4 or 5 items unread.
on android, iām regularly seeing negative numbers in the unread count.
the only way i can fix these is to go back to the feed agan and click the āmark as readā button.
