Hmm. I’m stuck with an unread article that I can’t seem to see.
I clicked everything, clicked the site, reloaded and it’s just stuck there with a 1, but not showing up.
https://img.skitch.com/20120731-g3bgp…
(my username is CDMoyer)
Ah. It went away. And reading further, I suspect this should have gone under “ghost unread items”
Awesome, glad this … went away?
If it’s driving you mad, just Insta-fetch stories on the feed and the unread count will correct itself. But it should be correct anyhow, and that’s what the Ghost topic is for. It’s very very hard to pin down the cause.
