Selecting Sphinn, former Marketin Land, http://feeds.sphinn.com/sphinn is redirecting to their website instead of displaying in Newsblur. Is it happening to me only ?
It looks like it is using an iFrame buster. If you are on a fast enough connection, NewsBlur should automatically switch you to the Feed view. I’d recommend trying to switch to the Feed view before the Original view loads. Ideally you would just be able to right click on the site, go to Site Settings, and change it to the Feed view. that hasn’t happened yet, but it will soon. Let me know if that fixes the issue.
Thank you, changing to Feed view in the site settings solved the problem.
Kind Regards,
Robert
