Use case: I use automation to auto tag stories based on ticker, company, sector, etc. which let’s me drill-down on specifics when I want to read stuff.
Problem: There does not be appear to be an ability to sort the tags a-z, z-a, date, etc. which makes it difficult to find specifics in the default sort order. The list must be scrolled top to bottom which takes {if/and/or/not} process in my head since the sort is rather random! ![]()
Currently, the order appears to be by story tag counts.
Adding a menu item is probably not a small task but it would be awesome to see a Tags preference items added.
