One of the feeds I read (http://www.zmescience.com/) recently added javascript to break out of iframes. It is incredibly annoying. It seems I can’t fix this with greasemonkey because my script won’t run until after it has already broken out. Have you considered trying to block sites from doing this on your end? This answer using iframe sandboxing (http://caniuse.com/iframe-sandbox) looks promising: http://stackoverflow.com/questions/36…
Yup, already use an iframe buster buster. It doesn’t work perfectly, though.
I also keep a blacklist of sites that do this. If you’re in an endless loop, right click on the site, go to Site Settings, and change to the Feed view there.
