how do I show only unread feeds on the left sidebar at the bottom, it only allows “full”
The Full is for the story view. The feed list should show “All/Unread/Focus/Saved” at the bottom.
It does not show those choices. To the right of “all” is a small gray dot, then a green dot then a larger gray dot, then the settings link
You’ll have to widen the feed list to see the words. You want the gray dot for Unread
thanks working now
