Show all items including read ones
Is there a way to show all items in the “all site stories” or folder view? I only see this to be possible on a per feed basis.
It sometimes happens to me that I mark something as read by mistake, close the tab, refresh it or load another view and then have problems to find that item since I can’t remember which feed it was in. A global all/read items view would easily help me going through my reading history.
You should see the all/unread and newest/oldest first controls in the top right whether you’re looking at “All Site Stories”, a folder, or an individual feed.
Make sure it says “ALL” instead of “UNREAD”.
Oh dear, thought this is just a table header where the triangle indicates newest first. Didn’t expect to find any options there. Thanks for the hint. :slight_smile:
