Hi, I’ve just noticed the “lots of new keyboard shortcuts” feature, and hit ? to have a look. The keyboard shortcuts page says Shift+J will move to the next feed with unread items. It doesn’t seem to work. I’ve nuked the cache and still no joy.
OK, slight error in my original post - Shift J isn’t “next feed with unread” it’s literally “next feed”. It still does not work in my browser.
A couple of other observations:
If I slide the importance slider to yellow, the first time I press shift J is get the first feed in my list. Subsequent presses don’t do anything. I can also lock the browser up pretty quickly by repeat pressing it.
If the slider is on green, it never does anything, but I can’t lock the browser.
Ah ha! It’s to do with having feeds in groups, and having groups collapsed.
All my feeds are in groups, bar one. That single feed is a “yellow” feed.
If I slide the slider to yellow, and expand my first group of feeds, Shift+J will cheerfully toggle between all three feeds.
If I collapse the group and try again, I can hang the browser.
In green mode, I have no stand alone feeds, so shift+J does nothing.
Also, it’s not like it _appears_ to do nothing (in that I can’t see it changing feeds because they’re collapsed and not visible) because the list of visible articles doesn’t change.
I’d like SHIFT+J to skip between collapsed groups, if that’s possible, but maybe that’s an unreasonable expectation. At least we now know what’s going on.
