Hello there!
The Saved Stories view is not loading on my Android app. It is working fine on the web browser, though. I tried un-/re-installing the app, but that didn’t fix it. Is anyone else seeing this issue?
Will
Hello there!
Will
I realized it might help to add more information:
In the main view of the NewsBlur app, the saved stories entry shows the badge with the correct count. But when I tap on that entry to go to the saved stories list (not expanding the row) the view just shows the Loading… message and keeps cycling the colored loading animation.
This is also happening in WinBlur (which I don’t think you maintain): the badge for the saved story count seems correct, but the list never loads.
