Same newsletter create multiple feeds
I have lots of newsletters forwarded into NewsBlur and it creates a feed for each incoming source email, which is what I want, the problem is it believes the same email containing an alias is considered as different emails and therefore creates different feeds for same origin.
For instance I am subscribed to a newsletter called hipersonica, they send emails from:
hipersonica@substack.com ← original address
hipersonica+valladolid@substack.com
hipersonica+tier-list@substack.com
hipersonica+buenos-dias@substack.com
hipersonica+marketing@substack.com
etc… all them in the form:
hipersonica+something@substack.com
every time they change the +something part a new feed is being created, if I don´t delete them frequently I end up reaching my feed limit. Same thing happen with others newsletters.
So, is it possible to ignore the +something part, or at least leave that as an option to the user to decide whether they should be treated as different feeds?
Ok, I launched a fix for this a few days ago and any email newsletter with the same List-Id should coalesce into the same newsletter feed. Let me know how that’s been working out.
I have been testing it and seems to be working, thanks
@samuelclay I just wanted to pop by and say, thanks. I think this change resolved a long standing issue I had where all newsletter emails from a large org (e.g. nytdirect@nytimes.com) were all routed to the same feed even if a different list-id. The behavior I’m seeing now changed not only to merge emails from different senders with the same list-id but also to split emails from the same sender with different list-id. Thank you!
Don’t know if it is related to this, but when I change a newsletter from the ‘Newsletters’ folder (that Newsblur automatically creates) to another folder, as soon as I receive another mail from the same newsletter, a new feed is created again in the ‘Newsletters’ folder.
Follow up, I think this is the problem that was happening with me.
This is one of the recipients: prvs=0692e951df=788350019_346285_1931@bounces.marketing.gedidigital.it
As far as I’ve seen the mails are in the form
prvs=’random prefix’=788350019_’random suffix 1’_’random suffix 2’@bounces.marketing.gedidigital.it
788350019 is always present, probably is the newsletter ID
Is there anything that could be done here to merge these newsletters?
Maybe one thing that could be interesting for Newsblur is to be able to manually merge feeds, maybe with custom rules, in case some of this happens
Edit: typo
