Is it possible to reorder the feeds/folders in newsblur? I would desperately like to ensure all my unfoldered feeds come last and I can move my folders about as I wish.
Currently this isn’t an option, but I think Samuel said somewhere it will be added eventually.
The current workaround is to rename the feeds to have a number at the front and set it to alphabetical sorting. Not ideal but it works.
I just put all of my feeds into folders and then name each folder starting with a number. If I want to reorder anything, I can just change the numbers of the folders.
