Reddit forum feeds not updating (rate limit?)
I have feeds for several Reddit forums. Newsblur has shown no new posts for the last few days. In the statistics I see this similar pattern:
Feed Fetch
2026-06-14 22:21:49 Rate Limited (429) (429)
2026-06-14 11:28:29 Rate Limited (429) (429)
2026-06-14 00:21:50 Rate Limited (429) (429)
2026-06-13 14:09:51 Rate Limited (429) (429)
2026-06-13 05:21:06 Rate Limited (429) (429)
2026-06-12 22:04:18 Rate Limited (429) (429)
2026-06-12 15:25:51 Rate Limited (429) (429)
2026-06-12 09:50:08 Rate Limited (429) (429)
2026-06-12 04:40:34 Rate Limited (429) (429)
2026-06-12 00:20:58 Rate Limited (429) (429)
2026-06-11 20:41:56 Rate Limited (429) (429)
2026-06-11 18:21:13 Rate Limited (429) (429)
2026-06-11 16:40:45 Rate Limited (429) (429)
2026-06-11 15:49:09 Rate Limited (429) (429)
2026-06-11 14:55:09 OK (200)
2026-06-11 14:03:09 OK (200)
2026-06-11 13:09:53 Rate Limited (429) (429)
2026-06-11 12:15:51 OK (200)
2026-06-11 11:22:07 OK (200)
2026-06-11 10:32:38 OK (200)
2026-06-11 09:46:08 OK (200)
2026-06-11 08:54:36 OK (200)
2026-06-11 08:04:16 OK (200)
2026-06-11 07:15:59 OK (200)
2026-06-11 06:27:30 OK (200)
Some low-signal related traffic in https://www.reddit.com/r/rss/comments/1u4j2pv/update_from_reddit_admin_on_rss_rate_limits/ recently.
(Incidentally, reddit RSS feeds seemed to get an improvement recently (sub icons as the feed icon in NB) … not sure if that’s a Reddit or NB improvement, tho.)
here’s one of the subreddits I like. Tons of 429s.
I have this problem too. I would love to see a response
Yep, those 429s were Reddit throttling our public RSS requests. Just shipped a fix: NewsBlur now pulls Reddit feeds through Reddit’s authenticated API, which has a much higher limit and doesn’t trip those 429s. It’s live now, so your subreddit feeds should start catching up over the next hour. Let me know if any stay stuck.
This seems to be causing a problem with RSS feeds for specific posts.
E.g.: Post: https://old.reddit.com/r/PostgreSQL/comments/1ucs1ap/multitenant_saas_architecture_postgresql_schema/
with feed: https://old.reddit.com/r/PostgreSQL/comments/1ucs1ap/multitenant_saas_architecture_postgresql_schema/.rss
When added to Newsblur seems to get the feed for the entire PostgreSQL reddit instead: https://old.reddit.com/r/PostgreSQL/
Also feeds contain wrong posts now, e. g. https://old.reddit.com/r/television/top/.rss?sort=top&t=monthly does not contain the top post of the month but recent posts.
Ok, individual Reddit post feeds (the /comments/ ones) were still broken because they got treated like a subreddit and pulled the wrong stories. Fixed and deployed now. They go through Reddit’s API too, returning the post followed by its comment thread.
Here’s the commit: https://github.com/samuelclay/NewsBlur/commit/2db2279c4b3232f9744dff548e25597a63c1c57f
Reddit’s “r/example” story tags are no longer working. For example, the RSS <category term="worldnews" label="r/worldnews"/> no longer shows “r/worldnews” as a story tag.
