Hi Clay,
I’m trying to add some reddit-groups which worked fine the other day but not today.
Example
https://www.reddit.com/r/TREZOR/.rss
https://www.reddit.com/r/bitpanda/.rss
Can you confirm or is this a prob on my side?
All the best!
Ralf
Hi Clay,
Example
All the best!
Ralf
i have www.reddit.com autoredirect to old.reddit.com and those feeds are working.
That worked!
Havn’t heard anything about this. And it’ll break when Reddit disables it. Any place where Reddit is talking about this?
i know nothing. i only accidentally found that workaround testing the link you’d given. you could check the site information dropdown for the feed and see what error it lists.
