Hi ,
I recently got Newsblur premium and it’s great especially the long awaited grid view for ios , here is some of my initial feedback
1- can we get notifications per folder , the main reason i use folders is to organize my feeds into how important they are , and i would like to get notifications for all feeds in a folder instead of having to add one by one
2- can we get instafetch per folder or globally ? and i’m not sure what pulling down in the android app does because it’s not instafetching
3- many of the apps and extensions in goodies and mobile apps section are either outdated or dead projects , the first party apps work great though and i wish you can add an official browser extention because the unofficial one is not working
4-is there a way to boost interval of feed polling ? , from what i understand you use a custom formula depending on how popular and active the feed is , but what is stopping you from making it for example 10 minutes for all feeds ? , from the feed owner perspective they wont like everybody doing that but you have one server polling for thousands of users so it’s a win win for everybody right ?
5- can you add 2fa to newsblur like you did with the forum ?
6-thank you for implementing Pubsubhubbub for youtube feeds , is there a way to auto detect it for other feeds ? i see many feeds that support it like mastodon feeds for example yet it’s not being used
7- how can you check feed statistics on the android app ?
8-minor issue : you have to have an account in newsblur in order to login to the mobile apps and then you can change to your custom domain , hope you can just have it as advanced options at the start
9-feed statistics seems to be missing from the android app
