Project Euler not working
I’ve tried, but it seems the Project Euler RSS feed isn’t working. Here’s the RSS feed link. Can anyone check if its working for them?
you can check the site settings for a channel and see what the actual request responses have been. in this case, it’s 401 unauthorized. is this perhaps a feed that requires a login? it is possible to set that up.
It does not require a login, I think, as I can access this same feed on other apps without a login. How can I set up a login to access any feed?
if you can access it on other apps then that’s not the probelm here, but in general:
Yes I can access in other apps actually. I checked it on feedly and its working there. Thank you for sharing that, I didn’t knew that could be done. Do you have any idea how to fix this?
