- horizontal scrolling is not smooth
- no back/forward button, no way to go back to the story (useful for feeds that aggregate links)
- screwed up layout for a lot of sites (not sure if it’s requesting desktop layout or some other problem)
- didn’t find an option to disable the inline browser
app version: 4.3.0b3
android version: 5.1.1
device: LGE Nexus 4 (MAKO)
username: besen
memory: normal
speed: 82 feeds in conn:1693 read:210 parse:119 store:173
premium: yes
prefetch: no
keepread: no
This is a known issue that was triggered by the most recent update to the Android WebView. See https://github.com/samuelclay/NewsBlur/issues/700
It will be fixed in the next beta release.
The faster this behavior can be fixed, the better. It makes the app nigh unusable for at least one common case (reading HN), *and* it’s easy to assume that it’s an intentional, if terrible, change (I trawled through every setting I could find looking for a way to turn it off).
I’m going to release the update later today.
FWIW, it looks like the chromium team has admitted it is a bug that should be fixed:
https://code.google.com/p/chromium/issues/detail?id=499331
However, as Sam said below, we have added some code to the NewsBlur app to make sure things behave correctly even *before* the chromium team fixes the regression.
