Can’t move feeds between folders that have the same name (one of them is a subfolder of another folder). If you delete one of the folders, the subfolder with the same name also gets deleted.
- “Folder”
- “Folder containing a subfolder”
— “Folder”
Moving feeds from “Folder” to the subfolder “Folder” does not work, nothing happens. Deleting “Folder” also deletes the subfolder with the same name.
It’s usually not a good idea (even more so with online services) to have multiple folders with the same names. Most operating systems can tolerate it (duplicate sub-folders) but it has been known to create problems for emergency file recovery in some cases.
You might want to try this:
1- move messages/content to temporary folders (each with a different name)
2- then erase all of the folders with duplicated names
3- create new folders where you need them (with slightly different names)
4- move the messages/content back where they belong
You might need to get creative with your naming but it will save you many headaches going forward.
Hope this helped a bit.
Let’s say that I subscribe to all kinds of feeds related to work and my favorite hobby. I arrange the feeds in folders so that I can easily read the work feeds while working and… you get the picture.
Top folder: WORK
Subfolders:
Top folder: HOBBY
Subfolders:
And now, for whatever reason, a blog that used to relate to work changes direction and starts writing about my favorite hobby and nothing else. Clearly, it has to be moved, right?
I see no reason why there should be a problem to MOVE it to HOBBY -> Blogs.
Sure, I can move the feeds one by one to a temporary folder, delete the folder I’m moving from (in this case both gets deleted) and then move all of the feeds once again. This is what I did. And it’s also why I created this bug report, because surely it should be possible to move sites between top folders into a subfolder of a different top folder.
In the live scenario that I encountered the problem, the “Blogs” folder was a top folder and I wanted to move the feeds to a subfolder, to get things organized. But it does not work and there’s no reason for it not to.
Again, it’s not a big issue, since most people probably don’t reorganize feeds that often. But when you do, it sucks that this doesn’t work (when you’re moving a lot of feeds)
I actually had the same problem - my solution was to suffix the subfolder based on their parent. So in your case, you would have:
Top folder: WORK
Subfolders:
- News sites W
- Blogs W
- Other W
etc. Based on a Twitter back and forth I had, this isn’t fixable on his end, so you can’t have duplicate subfolder names in Newsblur, period.
