Problem with Drudge
The normal Drudge Report feed that I’ve subscribed to for years stopped updating on Tuesday. This isn’t a Newsblur issue, if I browse to the RSS feed URL (http://feeds.feedburner.com/DrudgeReportFeed), it isn’t updated there either. I found a replacement site that does the same thing as feedburner (http://www.drudgereportfeed.com/rss.xml). I tried to add that as a second to compare the content of the two.
When I added the second site, Newsblur seemed to match them up and just renamed the original feed (Drudge Report became Drudge Report Feed), but the feed URLs and content did not change. Figuring that it might be due to trying to have two similar feeds in the same folder, I tried adding it to the root folder. Same result. I deleted both sites, and tried to just add the new feed. That re-created the original site (even though I used the new URL). I went into Site Settings and manually changed the feed address to http://www.drudgereportfeed.com/rss.xml. That is now getting redirect errors in Newsblur.
Any idea what is going on and how to resolve?
I switched over to Drudge Siren http://www.drudgesiren.com/rss.php  It’s not as good, but it’s working until the other feed gets repaired
