Seems like the connection was interrupted, maybe it’s my internet connection to blame (IDK), however in such cases I think it should recover, as I have an Internet connection up and running while this happens. What works is for me to do a page refresh (Cmd+R).
That’s weird. You should see a normal exception. If you load NewsBlur in a web browser, turn off wifi, and then click on a feed, you should see a well handled exception. I’m not sure how this happened.
If it’s any consolation, I see this problem pretty regularly. I use a 3-pane Split Left, Single Story layout. I’ll get these loading delays or hangs with the “All Site Stories” or individual feed. Sometimes, it will load enough feed items to fill the visual list, but hang trying to load more beyond the viewport.
I also see this issue pop up with browsing Newsblur with keybord shortcuts. I hit a wall where Newsblur won’t load any more feed items using j/k. Oftentimes I tend to “pre-load” items in the list by scrolling with the mouse, then moving back to the top of the list and browse with my keyboard.
Are you seeing the same error @rwatt? I have a fix for the error you’re seeing @alexelcu, but I can’t deploy it until tomorrow after I’ve tested some other monitoring work out.
