print selected selected news
Hello,
is there an option to print the current news?
Best Regards
Fabian
You should be able to just highlight the text you want to print and then use your browser’s print function to print just the selected text.
That works, thanks!
Is there a quick way to highlight the complete current news?
Not really. You could just use command+a to select everything, but you’d have to pre-load it first. Not ideal. NewsBlur isn’t really all that useful as a feed-to-print service.
ok, thanks!
