Possible to display feed posts within a specified date range?
Is it possible to display the posts in a feed within a user specified date range?
For example, if I wanted to display all the posts from Engadget for the dates of 6/20/2021 through 6/23/2021, would this be possible using Newsblur Premium Archive?
(Nothing special about that date range, I just made it up as an example.)
Edit - to be clearer, it would show the desired posts (clickable) subject line in a pane of the interface.
Anyone…?
From what I’ve been able to discover, I don’t think it’s possible even with the Premium Archive version. And I really don’t want to spend $100 to confirm it.
Yeah it’s not, but I really love this idea. I love it so much I want to implement it before the 403 forbidden feed thing. So listen, if I ship the 403 forbidden feed thing (see this thread: Feed Retrieval Problems: 403 Errors - #54 by animaux1), I would love to make this the next feature.
If anybody comes across this thread, please post and I’ll try and get it in. I would love this feature.
Sounds like it’d be cool!
Thanks! I’ll be watching for the update.
Can we talk a little bit more about this feature as in what would you like? How would you like to use it? Do you want to choose two dates to have a range between or do you want single click buttons like last week last month last year or couple years back, etc…
Samuel - thanks for the reply.
Ideally, there would be a very comprehensive search function which would allow the following parameters to be set (singly or in combination):
  • Date range - a full month would be great, but at least a week (or a single date)
  • Source feed - a single feed or multiple feeds
  • Subject line keyword - with And, Or, Not qualifiers
  • Article body keyword - with And, Or, Not qualifiers (probably not realistic)
  • Read/Unread status selection
  • (probably some other parameters that I can’t think of right now?)
The search results would display the date(s), feed name(s), Read/Unread status and the article subject line(s) in a pane of the interface - just like some email clients. The subject lines would be clickable and take you to the article’s body text - again, just like some email clients.
To set the date range it would have Start and End date boxes that you could either type directly into, or use those little pop up calendars that you’ve probably seen somewhere online.
For a Premium Archive subscription, the search functionality would work for posts over 30 days old.
Sorry to revive this after a year, but I was wondering what the status is? I just had a situation where I remembered seeing a new trailer in a folder, but forgot to save it. I searched “trailer” and it found every article with trailer in the title from the history of the feeds. This is fantastic, but looking for something that I saw today is kind of hard when I’m seeing things from 2016. I then tried to first apply the feed filters before searching. The filters disappeared as soon as I tried to search.
I would like to see at least the filters stick when searching. I don’t know if it would make more sense to put the filters on the search or have a search box in the existing filters (probably the latter). A third option would be to have the filters stick when searching.
Another solution would be a query system like Readwise Reader, though that adds a lot of complication, but allows the user to be more specific when searching like Me12345 suggested earlier.
