I created a NewsBlur account a while ago without a password. Later, I added a password, but I still can log in to my NewBlur account (from the web and the Android app) without providing the password. So basically, anyone who knows my user name can log in to my account. Please advise. Thank you!
You should be able to change your password. Go to Manage > Account > Change Password. Is that the dialog you used? Try it again and then try logging in without a password.
Thank you for your reply. I tried that several times with the same result: I can still log in without providing the password.
I’ve solved the problem! I simply left the Old Password field empty (previously, I tried to enter the password I used in the Sign In form) and specified a new password. Hope this makes sense. In any case, thank you for your prompt response.
