I’d like to be able to order my folders by dragging and dropping.
Currently, the only way I might be able to order my feeds would be downloading the OPML file, editing it as plain text, and then re-uploading it. Hardly ideal.
Another workaround would be to number your feeds in the order you want them (at least if you have them sorted alphabetically). Not ideal, and I agree, drag&drop would be nice to see.
Yep, the batch editor is going to be built soon. It will allow for drag-and-drop, and possible custom ordering.
