Basically what it says in the title
You mean switching between Full/Split/List/magazine/grid? It’s working fine for me. Can you post a screenshot showing the behavior?
I mean the reading view. It works per story or for the whole app, but doesnt set a consistent reading mode for a whole folder. I select an option for the whole folder and it says saved, but then in practise the change is not applied
Oh I see. Yeah that’s intentional. Feeds and folders override the global setting but the override does not propagate down to individual feeds from folders. But honestly once you set the right view per feed, because it’s sticky, should be enough.
