Newsletter sent from Fastmail is not readable anymore in Newsblur
I normally signup to newsletters with my Fastmail account that I then move into a “newsletter” folder. There’s a rule then that sends a copy to my Newsblur email so that I can read them there.
It used to work for all the newsletters, but recently (don’t know exactly when), one of the newsletters arrives in Newsblur without the content (see screenshots below).
This is how it’s supposed to appear:
This is what I see in Newsblur (basically there should be text between the 2 horizontal lines):
I tested the process using another email address other than the Newsblur one and it worked fine, so I’m assuming that something changed in Newsblur.
Any help wold be appreciated
If this is what I’m famliar with, it’s more that the email newsletter provider having very aggressive CSS styling for their posts, which do not play nicely with how NewsBlur embeds the content. eg.: the newsletter hard-specifies “white” text on a dark background, but NewsBlur allows the “white” text but forces a “white” background, making the text unreadable.
Try switching between the “Original”, “Feed”, “Text”, and “Story” views to see if any of them are suitable. Also, I’ve found that just using C-a in the browser to select all text can help normalize the text-vs-background contrast to make things readable, if annoying.
thanks for your answer and suggestions.
Sadly it doesn’t seem to be a problem of styling or CSS. I tried switching between the different views as you suggested and when doing so I opened the developer tools to inspect the content of the page and the text of the email is just not there.
I see the same issue with newsletters sent from HN Digest to my Newsblur-generated newsletter address. When I look in dev tools, regardless of which Newsblur view I use, the content of the newsletter has been stripped out almost entirely.
Ok I subscribed to both HN Digest and will see how it’s getting munged in the intake pipeline.
if you need, I could also send you some issues from the newsletter I mentioned in the first post
