Loving newsletters, it helps me keep all my email from Kickstarter under control. I have a little problem though regarding the order which they are loaded into the front end which causes me to accidentally mark them as read when I didn’t intend to.
I start Newsblur from the following bookmark https://www.newsblur.com/folder/every… . All the RSS stories load immediately, then I see the Newsletters feeds pop into the left pane. They don’t appear in the stories list (unless I reload or navigate back to all stories), but if I mark everything as read, they are marked as read along with everything else. They should either be loaded before the all stories list is populated so they appear at the start, or shouldn’t be marked as read unless they appear in the stories pane.
