NewsBlur new iPhone client (7.0) has issues on read states. When I read an article and hit next button, all articles are marked to be read on the feed.
I had the same issueâŚ
I also find on iPhone and iPad on v7 that once an item is read, itâs not possible to mark unread. The action appears to work, no error and unread marker is back, but story is still marked read when revisiting feed or folder.
There is no âmarked unreadâ or âsavedâ overlay any more when performing those action, although save does at least work.
Itâs definitely possible I broke the overlays. I had to refactor a ton of things to get this release out, it was epic. So if an overlay isnât showing that you expect it to, please take a screenshot and post it here. Iâll get it fixed.
As for the read states, part of whatâs happening is that I turned on the âmark-read-on-scrollâ preference for everybody. Make sure you turn that off if you are having issues with the read state. It seems to me that youâre reading in an order that isnât the intended order (newest or oldest first doesnât matter, but it has to be top down).Â
Yup, turning off âmark read on scrollâ seems to have fixed being able to mark stories unread (youâre correct about the scenario, I was marking something unread so that it would still be there when I came back later to the same feed)
Not really anything I can screenshot with the overlays, as theyâre simply not there. If I swipe left to mark unread, or right to save, there was previously a black overlay with icon & text to show a loading icon which then changed to confirm that the action was successful.
I need thos escreenshots to see the exact setup. Also things like ipad vs iphone, and which ipad view you have setup (stories on left vs bottom).
