missing images displayed in text mode
In some of my feeds, when I am viewing in text mode, it will show a missing image box. In other feeds, also in text view, it shows images. While in other feeds, it shows just text. There seems to be no consistency between text view. Shouldn’t it always be just text? If an image is missing, NewsBlur should not display it as a missing image.
The Text view just extracts the text from the original story’s permalink. It can have images if they are in the original story. The readability script I’m using does try to fix image URLs but that isn’t always possible.
Are there ways to modify the readability script to fix this?
Well, it’s a bug, but it’s already setup to handle this. So if it isn’t working then it is quite possibly difficult to fix.
