Is there an option to delete followers/following for a personal Blurblog?
I see there’s an old thread here:
But no answers since 2014
Oh, this doesn’t come up very often so I just haven’t built it. You can email me usernames and I can remove them manually.
You can delete all followers/following in my case (I think it will be simpler that way ^^)
Done
Thanks!
Can you delete/reset the interactions part too?
P. S. : It seems that “Fallowing” is not updating
Is it possible to clean this two items?
No cleaning possible?
If so do you think if you delete the blurblog and I create a new one that could fix it?
Aside from the generous offer to do it manually, I would also like to be able to manage this. The lack of this feature is why I don’t use sharing on NewsBlur, despite it being a feature I would love to use, and would drag my unhappy Inoreader friends over to use it.
You want to be able to remove followers?
Yes and delete/reset “interactions” ![]()
Is it possible?
Sorry, I don’t think I’m going to add clearing of notifications/interactions anytime soon, it’s just not high enough priority.
Arf ok, is it possible to delete mine and every interactions link to it?
A big clean up no cherry picking, please? ![]()
Ok, I deleted your 13 interactions.
Yes perfect, thank you!
