Hi, I just encountered a small hitch that I wonder if any of you can might help me with. Until yesterday, the stories from a selected feed showed up in a sidebar, with the article I selected in a large pane to the right. Now the feed is at the bottom, with the selected article in a large pane at the top. Can anybody help me change this back? Many thanks in advance!
Yeah, you want to go into the preferences (click the gear in the bottom left of the screen).
Under the “feed” tab, scroll down and look for “Story titles pane”. Here you can change what position you want your feeds/articles to be shown in.
Thanks!
I was on my iPad. That’ s why I couldn’t find it.
Ohh, just drag the divider down to move it back to the side.
