I’ve got some kind of large print running in the background. I don’t know what that is. I’ve cleared my cache and rebooted. This is the only place I see it.
Its from the publisher. They’ve injected something in the view. I recommend switching to Feed view (bottom left of the story pane).
Thanks. But switching to Feed View did not change the problem. The large text is still there. It’s there on startup as well.
Im not really sure what you mean when you say it’s “from the publisher”?
The feed publisher. The folks writing the feed.
Hey. so with a little googling I figured out the problem. One of the extensions on my browser was causing the problem through the adblocker. I’m not sure which one, but I disabled my extensions a few at a time till the problem went away. So, not a Newsblur problem. Thanks for helping.
