First, NewsBlur is awesome. Great replacement for the turd that Google Reader has become. Worth the money and very possibly a marriage proposal.
Now: is there a way to get a keyboard shortcut to go directly to “everything?” Perhaps “e” or something?
Gosh, that Everything view is soooo slow, I can’t imagine anybody using it. Does it work well for you?
Heck yeah, it’s the only view I use, usually. I don’t notice it to be slow at all. Takes some time to fetch the articles, but the forward-and-back navigation is fine. Better than Google Reader, for sure. And my computer isn’t particularly fast.
OK, you got it. ‘E’ is now the keyboard shortcut for Everything. Let me know if that works out OK.
Thank you so much. I appreciate it.
