For the last week or so I’ve been having an issue when I load up NewsBlur, all my stories show on the right pane but then that area flashes and all the stories vanish.
I tried loading NewsBlur in incognito mode in Chrome and everything worked as it should which led me to believe it’s a extension I have installed that’s causing the issue.
So I disabled all my extensions, re-enabled them one by one and reloaded the page. When I enabled the LastPass extension (version 3.1.33) the issue started happening again.
Here’s a video of the issue happening in case I didn’t explain the problem very well. https://www.dropbox.com/s/sttgejn09uv…
Was just wondering if this is an issue with the site or an issue with the extension and/or if anyone else can using the normal branch of Chrome along with the LastPass extension can confirm this is an issue?
Chrome version: 35.0.1916.153 m
LastPass version: 3.1.33
This isn’t an end of the world issue as I can generally get the site to work correctly with the extension installed if I click the All Site Stories bar a few times to reload the right hand section.
