iPadOS: j key skips several posts after app-switching
iPadOS: j key skips several new posts after app-switching
Open a feed with dozens of new items. In my case: Hacker News: Newest
Find a series of new items in a row, start at the newest.
Press j to move into a story that triggers the problem.
Press ⌘+O to open the story, in the Safari browser (not in-app Safari)
Press ⌘+Tab to switch apps from Safari back to NewsBlur.
Press keyboard ‘j’ to go down to next item. Instead of going directly down to the next story as it does normally, NewsBlur will skip over several new items to one that is farther down the list.
As of right now, the story that triggers it is “Osaka bans smoking on all of its streets, vaping included.” This is the 19th story in the feed right now. It skips 5 items, going to “FTC Takes Action Against [company name] for Alleged Lax Data Security”. Another story that triggers it is “The ocean teems with networks of interconnected bacteria”. In this case it skips 12 items to: [company name]: Cheap, no-nonsense email.
I can reproduce this fairly consistently. To trigger it again, I have to close the app and restart it. The story that I press ⌘+O on does not have to be unread. However, moving j to move into the triggering story seems to be a requirement to trigger the problem. I do not run into the problem if I just start by scrolling to the trigger story and tapping my finger on it, then pressing ⌘+O .
Configuration details:
NewsBlur on iPad, version 13.1.7, iPadOS 18.3, two different non-Apple Bluetooth keyboard devices made by different manufacturers.
iPad is rotated to portrait mode
Feed options:
Newest first
All stories
Leave unread
2-column layout
medium amount of content: 4-line symbol, not 2 or 6
XL font size
Comfortable
Dark
update: the same problem also happens with the ‘k’ key, that happens with the ‘j’ key. I switch back into NewsBlur with ⌘+Tab, then press ‘k’, then the current item in the feed is several items farther down the list than it ought to be.
Oooh, that’s an interesting hint as to why this is happening. @dejal, got any ideas?
I can’t think of a cause offhand. Thanks for the detailed description; I will try to reproduce the issue, and will fix it if I can reproduce it, or can figure out a possible cause.
