The Android Client is in very bad shape!
- The Mobile Providers reduce the Bandwith after you used up you data ammount, your client is not useable after this.
- Remove the Adds,…im paying for this you must be joking!
- I would like offline support, so i start the app in the morning and the client downloads 50 stories from each feed. look at the greader pro for inspirations
in regards to #2, what ads? The May 10 build (https://play.google.com/store/apps/de…) doesn’t have any ads that I’ve seen.
Half of the sreen are adds, here is a screenshot.
Check this out! Do you see the big shell add? Half of the screen!
http://imageshack.us/photo/my-images/…
nope - same feed, same article: http://i.imgur.com/HuqSDPE.png (the EVO software doesn’t allow for screenshots)
I have some issues with the Android app (hopefully addressed soon), but I have never seen an ad in it other than what may exist in the feed itself (which your Shell ad looks like).
Seems like it might be a feed ad rather than a newsblur ad.
Yeah, that’s an ad from the NYTimes. NewsBlur would never serve ads. It’s against my fundamental beliefs for how a site like NewsBlur should run. Customers pay for service and no double-dipping (i.e. making them pay more for more service).
