Importing feeds and then upgrading marked them as read
I imported a bunch of feeds and then upgraded to Premium Archive, which I guess I did in the wrong order and now all of the archives are marked as read.
If I add a new feed now (after upgrading) then all the archive gets marked unread, is there some way to get this to apply to feeds I’ve already added? Deleting and readding them doesn’t seem to fix it.
We can probably get this fixed. What’s your username?
zcarterc
Can you tell me which feed title is incorrect and what you expect it to show? If you just import feeds, all of your feeds are marked as read up to 24 hours ago.
I would like the full archive of all feeds to be left unread, unless I override ‘Auto Mark as Read’ for a feed.
