sorry i tried to crawled through the threads and couldnt find a clean answer…how do you search for thing in the feeds/saved stories?
i see that there is a keyboard shortcut i…but somehow i couldnt get it to work, i am sure it is probably a silly error, please kindly help! thanks so much!
On the web, the search box is in the top right after you open a feed or saved stories.
Hi Samuel,
thanks for the reply.
Somehow I still can’t see it…adding a image here for your reference.
does it look/work like a box where I can just type in keywords to search for matching feeds?
thanks
It only appears for feeds, not folders.
Ah i see it now…thanks
Will NewsBlur add search function on folder level anytime soon?
thanks!
