Some sites set security options to deny loading into frames. NewsBlur’s story view works by loading the site into a frame. Which doesn’t work for those sites.
I built a Firefox extension which overrides that setting, allowing all sites to load into NewsBlur’s story frame.
https://github.com/arantius/nbfod
I call it the NewsBlur Frame Options Defeater.
