Sometimes (it seems like often with some feeds), grabbing the “text” view never works. It doesn’t fail, the progress bar just sticks at 99 or 100%. It would be great if there was a “report a problem” element in the UI that I could use to report problems with a specific feed right now. I assume there are logs on the backend that could then be correlated to my problem report.
