The feed http://www.happletea.com/feed/ isn’t parsing certain posts, even though it passes the feed validator service (http://validator.w3.org/feed/check.cgi?url=http%3A%2F%2Fwww.happletea.com%2Ffeed%2F). Specifically, it seems to fail on the “Fimbulwinter” and “Complaintsgiving” posts. Not sure why though. If it helps, the Firefox RSS viewer seems to parse them properly.
So the feed author must’ve screwed something up, because the Fimbulwinter story has the same permalink/guid as the “Money to Burn” story, which is where it’s going. Let them know and they can probably remedy it.
