Now, all of a sudden, folders display all items by default, instead of allowing the user to select folder display categories. Is this due to the Sept 13 system mod “Mark as read now allows you to select a number of days back: 1, 3, 7, and 14 days.” ? Can we have those other functions back?
I don’t think this is correct. Folders can still display unread or all stories. It’s in the bottom of the screen. Since this is your second issue, I suggest you reload the site and ensure you can see the bottom bar. See blog.newsblur.com for a screenshot of what you should be seeing.
Oh! Ha! I didn’t see it down there … thank you.
