Hello,
Normally newsblur is handling quite well post on multiple pages, which allows me to read most of my rss feeds without leaving newsblur.
However this does not work for some website, see examples below:
http://teens.webmd.com/girls/news/201…
http://edn.com/design/power-managemen…
Would it be possible to fix this?
I assume it’s getting the comments on that second link? I use Readability, which has pretty sophisticated heuristics for finding the story’s content. It’s not infallible and it’s also not really in my domain to fix. I regularly upgrade the script, though, and I’ll check now to see if anything’s new on that library.
Upgraded readability, which might help the second article. https://github.com/samuelclay/NewsBlu…
Alright, thanks for the help. I tried with readability directly and it does not work for both site (even with the new newsblur update).
I contacted readability directly will see if they can improve it.
