Forum Userid Problem
Somehow I ended up with two forum userids - this one and one under an older email address (hammondjh@runbox.com). I would like to use the older email address (which matches my current Newsblur email) but when I try to change it I can’t becuase the old userid is still around. But I can’t login to the old userid because the password is no longer valid, and if I try to reset that password I get an “An error occurred: You are not permitted to view the requested resource.” error message.
I would like to delete the old userid and then set the email for this ID to the old email address.
Done, I merged that account in this one, so when you login with the old email, it will login to this account, which inherits all of your old accounts data.
Thanks - I appreciate the quick resolution!
