As of today, the “everything” view (https://newsblur.com/folder/everything) as well specific folder views just hang forever with the pulsing blue loading bar. Going to a specific feed does work as expected.
I tested both Firefox 46 and Chrome 47, both show the problem.
My guess is that browser extensions are not the culprit, because I see the same problem if I create a fresh Firefox profile with no add-ons. But for completeness, I currently have:
CipherFox
Copy ShortURL
Ctrl-Tab
meta-q-override
Mozilla Tree Status
No Flash
PDF Viewer
Restartless Restart
Tab Stats
Tree Style Tab
Here is the console output from loading /folder/everything in Firefox:
Woah, there’s something fishy going on with that console output at the very top. I just pushed out an update, so try force/shift reloading NewsBlur and seeing if you still get the same console output.
Also, what’s your username? I can take a look at your account and see if I can reproduce the same conditions.
After a shift-reload, still the same broken behavior. The console message “The west onresize_end callback is not a valid function.” is still there, if that’s the one you mean.
Awesome, thanks so much for reporting this! Found it and fixed it. Turns out it was caused by faulty tag stripping and an errant story in Planet Mozilla that was incorrectly escaping tags.
