In the iOS app, if you open the first item in a list, mark it as unread, then scroll to the next item, the first item is marked as read. This only happens on the first item in any list. A workaround is going back to the list view and directly selecting the next item after marking the first item as unread.
Thank you for this very detailed support ticket. I have fixed the issue and v3.0.1, which I should be releasing soon enough, will have the fix.
If you can’t wait for the fix to go over the App Store, you can download it at www.newsblur.com/ios/download.
Don’t bother downloading that build. It’s busted for iOS 7. Even if it somehow got through the installation loop, it would look ridiculous. In fact, that’s the work I have cut out for myself to fix. I’ll try to get the iOS 6 SDK loaded back on there soon, but hold off on downloading that until tomorrow.
