When I click on a feed, the first article in the feed shows up in the reading pane. Naturally, I read it. However, NewsBlur will not recognize the article as “read” until I actually click on the article in the article list.
It’s a minor thing, but it’d be great if NewsBlur marked that first article as read once the article is “open” for more than 5 seconds (or if I scroll).
Your mouse indicator is locked, isn’t it?
I’m not sure I understand. Mouse indicator locked?
That little red nub on the left-side of the Feed view. Does it move with your mouse? Otherwise, how are you getting to the second story? Are you just scrolling? Moving up the red indicator would help. Let me know if that doesn’t work.
Yeah, it doesn’t move. It also only shows up when I mouse over the Next Unread button and disappears as soon I move the cursor over the actual content in the Feed view.
